guibo question
  • vandol
    • Jul 2009
    • 152
    guibo question
    I torqued it down and everythings where it should be..
    but the guibo itself is warped from the torquing everything.
    Is that normal?
    325i
  • SkiFree
    • Jun 2011
    • 2766
    pictures would be helpful in this case.
    ADAMS Autosport
    • vandol
      • Jul 2009
      • 152
      yeah, emails being slow
      325i
      • vandol
        • Jul 2009
        • 152
        pic
        325i
        • JRector
          • Apr 2011
          • 453
          What the hell? I JUST got done doing my guibo 20 min ago and it never did that. It looks like its not seating properly.
          • JRector
            • Apr 2011
            • 453
            Hold on... It looks like you have the guibo cover still on.. But the guibo isnt inside the cover like it should be..its behind it. Am i looking at this wrong?
            • vandol
              • Jul 2009
              • 152
              if i remember thats how it looked when i took it apart, isnt that just a balancer?
              325i
              • JRector
                • Apr 2011
                • 453
                Whether its a balancer or a shield, the guibo goes inside of it.
                • vandol
                  • Jul 2009
                  • 152
                  how? remove it and flip it?
                  325i
                  • Cronopoulos
                    • Jul 2011
                    • 2187
                    Who ever assembled that to begin with shouldnt be working on cars. The Guibo as mentioned above, should fit in the cover/balancer.
                    Project log -- DIRTY 30
                    2.7i * Megasquirt tuned * E85 powered
                    • JRector
                      • Apr 2011
                      • 453
                      Get rid of that shield. Most people do anyways and then 3 bolts go from the driveshaft to the guibo. Then the other 3 holes in the guibo go to the tranny.
                      • reelizmpro
                        • 9465
                        Back away from the vehicle. Balancer cover is backwards. That guibo may not last very long even after you get it installed correctly.
                        88 M3 - LACHSSILBER/SCHWARZE
                        • mr.vang
                          • 4371
                          Originally posted by vandol
                          pic
                          it look like its not even connect to the shaft, just the flexdisc and tranny end. the bolts got to go through the shaft end, flexdisc, tranny end.
                          • JRector
                            • Apr 2011
                            • 453
                            Take that cover off.. If you want to keep it then take it all apart and do as i said. 3 bolts connect the driveshaft to the guibo and then the other 3 bolts connect the guibo to the tranny
                            • vandol
                              • Jul 2009
                              • 152
                              alright so flip or just straight up remove it..
                              so i would need to pick up a new set of bolts, because the shield had studs attached to it
                              325i
