Driveline Possibly Out?
  • brutus87
    • 6280
    I noticed today that when i'm in low speeds, or taking off from a standstill, you can hear a thumping sound coming from below the car. All of the gears shift smoothly. I can't hear it above 25 miles per hour, maybe because its too loud outside? Anyways, has anyone encountered this type of thing? What was it? Any help is greatly appreciated, thank you.
  • brutus87
    • 6280
    Car: 1988 325is, 5 speed swapped from a donor car.
    • jclar
      • 265
      Can you feel it at all? mid car, rear, front?
      '86 325es M50
      • reelizmpro
        • 9552
        Could be many things like a center bearing going out, u joints, axles, worn diff. Hard to tell without actually being there. Maybe you should have a shop look at it before something happens. I went to a meet 30 miles away from home when my center support bearing broke. I knew it was going out but I didn't think it would break on me (I was taking it easy). Needless to say, I didn't make the meet and it was not the way to spend a friday night.
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
        • Cronopoulos
          • Jul 2011
          • 2187
          With the "thumping sound" my money is on the CSB...
          Project log -- DIRTY 30
          2.7i * Megasquirt tuned * E85 powered
          • accident
            • 7303
            Sounds exactly like the symptoms I had when the CSB went bad. Replace the guibo at the same time.
            Moral of this story?
              A thumping from under the car in the lowest gears that gets worse when accelerating briskly will usually be from a failed center support bearing. And failure of the center support bearing will almost always be caused by binding u-joints in the drive shaft.Meaning that the only long term fix is to replace both the CSB and the drive shaft.
              • brutus87
                • 6280
                So I replaced the driveline and CSB. Noise still there. I think it may be a noisy throw out bearing or tranny.
                • Cronopoulos
                  • Jul 2011
                  • 2187
                  Stock tranny mounts?
                  • brutus87
                    • 6280
                    No, they're new. I replaced the oil on the tranny, it had barely anything. Im thinking the tranny is fried because of that :(
                    • DrLeadFoot
                      • Aug 2011
                      • 461
                      Is this common?
                      Instagram: @DrLeadFoot
                      • brutus87
                        • 6280
                        Whats common?
