Looking to find out exact production of small vs big guibo
  • Flash
    • 688
    http://www.realoem.com/bmw/showparts...43&hg=26&fg=05
    Ok just to clear this up:
    so all etas up to 6/86 production, and all 325i cars from 9/87 and on are small guibo...correct?
    Im guessing all the small guibo driveshafts are going to be the same since the distance from the CSB to the diff is obviously the same, and the tail housing/harmonic balancer to CSB is the same, right?
    Inquiring minds need to know!
    • 37833
    That's mostly correct. There's no EXACT answer to the question but it seems that most of the cars that have them were the 87 Eta and some 88 Super Etas (but not all 88 cars).
    Grover Beach, California
    BimmerHeads.com
    • reelizmpro
      • 9558
      According to realOEM...ETA's produced 5/86 - on. 325iX transfer box. All M3's and 325iC's. I cross referenced the 26-11-7-511-454 part number for E30's that used the large guibo.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • Wanganstyle
        • 2828
        my 04/87 build ETA has an original large guibo ETA trans and matching original large guibo Driveshaft
        between large guibo and small guibo G260 and matching driveshaft, only the triangle junction @ transmision is the same. one can swap the transmission output triangle from small size to large size triangle output if desired; its factory designed to be swappable
        • jw 325ic
          • Sep 2006
          • 1360
          According to realOEM...ETA's produced 5/86-11/86. 325iX transfer box. All M3's and 325iC's. I cross referenced the 26-11-7-511-454 part number for E30's that used the large guibo.
          Are you saying 325ic's have large output flanges?
          • reelizmpro
            • 9558
            My mistake, it's 5/86 - on.
            JW325iC...according to realoem, yes. Do a part number search for the large guibo.
            88 M3 - LACHSSILBER
