Grade 8.8 Guibo bolts
  • lolcantturn
    • 4588
    I got pretty good quality grade 8.8 guibo bolts from Loews on my E30 M50 swap. It's a small guibo so they're 17mm. I haven't clutch kicked or anything as I'm kind of scared, but is this enough?
    Originally posted by TSI
    OEM+
  • Jafxod
    • May 2011
    • 1301
    No way
    Sub'd
    • lolcantturn
      • 4588
      Actually it wasn't a question of "Will it work or not" Jim, it was a question of is it good enough.
      OEM+
      • Jafxod
        • May 2011
        • 1301
        I know im just being silly. Any idea where the rest of my guibo bolts are? Theres three on the guibo on my work bench.
          • 34827
          I hate to get overtechnical, but 8.8 isn't a "grade", it's a "class". SI units (metric) vs SAE (imperial)..
          but I'd think they'll be fine. I generally don't like generic bolts because the protective coatings aren't as good as BMW original bolts, but the strength of the steel shouldn't be an issue.
          • Sagaris
            • Sep 2009
            • 2243
            For single shear with (6) bolts at a threaded diameter of 10 mm. Assume your engine output is 200 ft-lb of torque for calculations sake (271 Nm). Multiply that by a Getrag 260's first gear ratio of 3.83 to give a max torque of 1038 Nm. Suppose the distance between the centerline of the flex-disk to the centerline of the bolt is 30 mm (0.030 m) gives a force of 34,600 N divided by (6) bolts = 5767 N per bolt.
            The shear stress on one bolt would be Force/area with an area of
            pi*0.005 m^2 = 7.9x10^-5 m^2
            Shear stress = F/a = 5767 N / 7.9x10^-5 m^2 = 73,000,000 N/m^2 = 73x10^6 Pa = 73 MPa
            The yield strength of a class 8.8 bolt from http://www.boltdepot.com/fastener-in...ade-Chart.aspx is 640 MPa
            This is assuming that the flex disk, clutch slip, and driving style makes shock loading negligible (not sure how true this may be). I guessed on the radius of the flex-disk.
            According to these calculations your safety factor is 8.7 and that bolt will hold up fine.
            • Jafxod
              • May 2011
              • 1301
              Assuming that the flex disk makes shock loading negligible (not sure how true this may be) you will be fine. YI guessed on the radius of the flex-disk.
              If that was shorter I would sig that
              holy fuck
              • lolcantturn
                • 4588
                Holy fuck legitimately shit myself
                Amazing post. Thanks
                OEM+
                • Kershaw
                  • 11822
                  AWD > RWD
