the hell happened? No engagement
  • lolcantturn
    • 4588
    One step forwards, twelve steps back.
    Just fixed my fuel problem when my M50 was hesitating, 30 seconds later I felt something in the driveline just go and there was no power to the wheels. I put a new throw out bearing in the car so there's probably 3000 miles on it, the clutch came with the motor but it was in great shape. The only failure i suspected was the fact that I had a getrag 240 rattle on idle, but that's pretty normal. There's a lot of feel on the slave. I can put it into gear with no problem but it won't engage. guibo and guibo bolts are all there.
    Originally posted by TSI
    OEM+
  • lolcantturn
    • 4588
    Also, the clutch I was using was an OEM E36 unsprung clutch mated to an OEM flywheel, I think it's dual mass? Regardless, is it wise to put a sprung clutch on? My friend has an unused ETA clutch and flywheel laying around.
    OEM+
    • Jaxx_
      • Dec 2009
      • 1880
      with the car off and it in gear, does it move or not?
      • lolcantturn
        • 4588
        It does indeed move
        OEM+
        • scottinAZ
          • Dec 2009
          • 1312
          sounds like the clutch is gone..... dollars to donuts the disk shed the friction material on at least one side.
          I saved 15% on my Bimmer parts by switching to ...
          • Dj Buttchug
            • Jun 2010
            • 7688
            banking on this right here
            Turbo M42 Build Thread :Here
            Ig:ryno_pzk
            I like the tuna here.
            Originally posted by lambo
            • lolcantturn
              • 4588
              That's awkward, it was grabbing completely fine.
              Can I use a sprung clutch on a dual mass flywheel? Currently have an E36 DM but an OEM unsprung hub.
              OEM+
                • 37834
                The dual mass flywheel is intended for the non sprung disc. The real question is why are you using the dual mass flywheel? :) I would also be weary of the transmission's condition, the 240 is pretty damn weak. A friend broke his trans with an M50. There's always the chance that the diff broke internally as well.
                Grover Beach, California
                BimmerHeads.com
                • lolcantturn
                  • 4588
                  240 is fine and so is the diff, I baby my car but I plan on replacing everything when I go turbo anyway. The dual mass is stock on the E36 M50, ain't it?
                  So dual mass + sprung hub = no no??
                  OEM+
                  • Dominic49
                    • Feb 2007
                    • 1373
                    you can run a sprung with the dual mass, its just slightly redundant.
                    regardless your probabbly going to need to pull the transmission. could be a bunch of different things but most likely something wrong with the pressure plate (broken strap or the like)
                    • lolcantturn
                      • 4588
                      Geeze I hope it's not the flywheel, I don't think I have an OEM setup.
                      In terms of drivability, how would a dual mass and a sprung hub feel or should feel?
                      OEM+
                      • lolcantturn
                        • 4588
                        Bamp
                        OEM+
                        • lolcantturn
                          • 4588
                          OEM+
                          • Dominic49
                            • Feb 2007
                            • 1373
                            the dual-mass/sprung hub isn't there to help with shifting feel as much as it is there to smooth out the pulses from the motor as then enter the gearbox
