Help! My drive shaft shrank!
  • io_RobbieRodgers
    • Nov 2011
    • 57
    This totally killed my buzz after getting my rebuilt engine running tonight. The drive shaft is about 3/4s of an inch short of the transmission, I can't even get the bolt far enough through the guibo to try to pull it forward mechanically.
    How did this happen? How do I fix it?
    And no, I didn't install the suspension subframe backwards, I nearly died of a panic attack when that possibility ran through my brain.
    Reformed E34 addict. 1993 525i/5 - 1995 525i/5 - 1991 318i/C
  • ScHpAnKy
    • 1573
    there's an adjustment collar further down the shaft, with a collar nut, loosen the collar nut and stretch the driveshaft as far forward as possible. Also make sure your differential isn't moving around, now...
    91 318i | 87 535iS
    • TurboJake
      • 3780
      +1
      Leave Me Transaction Feedback
      • scottinAZ
        • Dec 2009
        • 1312
        pretty sure they make a little blue pill for this
        Like the others have said, there is an expansion joint in the trans, extend it, and you are fine....
        I saved 15% on my Bimmer parts by switching to ...
        • io_RobbieRodgers
          • Nov 2011
          • 57
          Found out after about an hour of struggling last night that it telescopes out, it just refused to extend while it was lined up with the trans. Thanks guys!
          • TobyB
            • 5298
            Snug the nut up now that you're lengthened...
            t
