Something is wrong... Diff question.
  • SwiftE30
    • Jun 2010
    • 998
    So I have an 89 325i convertible 5speed and from everything I have read this car is supposed to have a 4.10 LSD, I've also read that it could have a 3.73 LSD.
    I wanted to check to make sure it was in fact an LSD by jacking the back end up and spinning one tire. If it truly is an LSD both tires should spin in the same direction. Mine do not, which leads me to believe it is an open diff.
    My dad bought this car brand new back in 89 and the diff has never been replaced or messed with. How is this possible?
    1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
  • LJ851
    • 7919
    Not all verts had LSD's. From what i have seen they also follow coupe specs and are 3.73 for 5speed and 4.10 for autotragic.
    Lorin
    The M30 is God's engine.
    • reelizmpro
      • 9559
      Although many verts do have LSD, it wasn't a standard option.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • SwiftE30
        • Jun 2010
        • 998
        Ahh ok. I hadn't read that anywhere, but that sucks.
        I'm going FI anyways so I'm looking for a 2.93 LSD now. I know there is a 325e at my local JY and those are supposed to have that diff. Let's hope it's still there.
        I am however having second thoughts about the 2.93. Anyone think a 3.25 LSD would be better gearing for FI w/ 97 '3 zf trans?
        • reelizmpro
          • 9559
          Only 86-87 year model ETA has that diff. You want one out of an eS. 84-85 ETAs had 2.79 gears.
          88 M3 - LACHSSILBER
          • SwiftE30
            • Jun 2010
            • 998
            so if the eta i found is in fact an 86-87 it will have the 2.93lsd? and are you saying that the 2.97lsd from the 84-85 ETAs would be better for FI
