5 speed swap, almost there! questions??
  • new2bmw
    • Oct 2006
    • 387
    Hey guys. I have an 84 318i auto and am trying to collect the parts for a swap. I have a tranny, shift linkage, manual rad, drive shaft, center console and diff so far for the 5 speed swap. I need to know exactly what else i still need, yes even the obvious stuff. i have read a ton of threads and there is no comp[lete list of parts, that i can find to do entire swap, including the small bits and pieces. I need to start collecting the parts to have it done by summer. cheers guys and thanks for your help
  • JFarhanbod
    • 2151
    Drive shaft (MUST be from the manual car with your engine. IE M42 drive shafts are longer than M20 drive shafts)
    Master cylinder
    Slave cylinder
    Transmission
    Clutch and related parts (flywheel, bearings, etc)
    Clutch lines
    Clutch pedal set
    heres a good guide:
    • jeffnhiscars
      • Jun 2011
      • 6011
      you can re-use the console and radiator. Ask me how I know.
      Alice the Time Capsule
      • nick526
        • Jan 2011
        • 258
        x2 on the radiator. You will need the manual trans brace as well. I believe the center support bearing is different between early and late cars.
        I also had an issue getting the center exhaust mount to line up, I ended up just leaving it unbolted as it was still quite soilidly mounted.
        Defininitely rebuild the shift linkage before you install everything.
        I miss the old BMW
        • AussieTemplar
          • 107
          I am in the middle of doing a 5 speed swap and this, plus the trans, pedal box, tailshaft, fly wheel and clutch kit is what is needed.
          All of this is from BMA.
          26 11 1 225 624, Drive Shaft Flex Joint - $37.00 Febi
          21 52 1 156 000, Clutch Master Cylinder - $45.85 FTE
          21 52 1 116 300, Clutch Slave Cylinder - $35.13 ATE
          23 71 1 175 939, Transmission Mount - $6.30 each CRP
          Short shift kit (z3) - $95.00
          11 21 1 709 681, Pilot Bearing (Spigot) - $7.35 SKF
          11 14 2 249 533, Crankshaft Seal - $7.79 CRP
          23 14 1 354 071, Back Up Light Switch - $14.33 Hella
          23 12 1 205 340, Output Shaft Seal - $2.21 Elring
          26 12 1 226 723, Center Support – (This is for an 89 325is) - $18.20 – MTC
          1989 Australian Delivered 325iS Mtech 2.
          Fully worked M20B31 stroker. 143kw atw/285ntq atw.
