Transmission shifts worse after adding gear oil...
    • 34844
    redline MTL in my ~275k Getrag 260 - still shifts pretty smooth.
    stamar - shut it.
    • quikveedb2
      • Sep 2007
      • 2258
      Originally posted by stamar
      You used the wrong stuff with gl5 gear oil.
      You really could have saved yourself a lot of time and just wrote that, instead of the novel above. Believe it or not, I'm familiar with Google, I spent a fair amount of time on Bob is The Oil Guy reading while I was waiting for some replies in this thread. You have given SOME good info, and I appreciate that, but you should check the condescending attitude at the door. This forum is for sharing information. If you can't be troubled to waste your time replying to a thread, don't, r3vlimited will live on deprived of your infinite wisdom and Google skills. It's clear you've rubbed more than 1 person the wrong way.
      That said I'll work on getting the seized drain bolt out and drain & flush the tranny, refill with GL-4, and see what she does. I still suspect that being driven for who-knows-how-long with no gear oil at all in the case will have done more damage than a couple hundred miles of being driven with GL-5, but what do I know.
      You know why you're drinking that Pabst? No its probably not because it was the first beer you grabbed. It's because you're a winner.
      • VinniE30
        • 2113
        How did the transmission get to the point of having no gear oil?
        Even if there was a leak at the pan gasket, wouldn't the pan still have some oil in it? From the looks of mine it seems you can't even get out all the oil using the drain bolt, since there would still be some sitting at the bottom of the pan.
        Do you guys know the ATF, Redline MTL, GL-4, GL-5, B&M Stickshift, and Lucas compare in viscosity? I'm looking for something a little thicker to prevent the inevitable leaks.
        Zinno '89 <24v swap in progress>
        • FLG
          • Sep 2011
          • 3165
          Fix the leaks not the fluid...transmissions aren't as forgiving as engines when it comes to fluid viscosity.
          Probably leaking from the rear seals which aren't hard to replace.
          Sent from my Galaxy Nexus using Tapatalk 2
          -Build http://www.r3vlimited.com/board/showthread.php?t=295277
          • quikveedb2
            • Sep 2007
            • 2258
            If I'm not mistaken, the problems with GL-5 Stamar is referring to are due to the fact that GL-5 has higher sulfur content so the anti-wear barrier it created is actually harded than the (brass) syncros, so when that barrier peels off, it brings some of the synchro material with it, causing damage. Granted a lot of this is information I've collected from the internet so reliability is questionable as always.
            http://www.bobistheoilguy.com/forums...&Number=729255
            http://www.bobistheoilguy.com/forums...Number=1157073
            I am also perplexed by where the gear oil actually went in the first place; where would a leak from the rear seal be visible, if anywhere?
