transmission fill plug help
  • Dsun
    • Jul 2011
    • 371
    Noob question: what kind of 17mm hex wrench/bit are you guys using to remove the fill plug on transmission? I got a 17mm 1/2 drive but its so large once I got it on my rachet I cant get it in place. Couldnt find any 3/8 hex bits. Also is there a real difference between allen and hex? both look the same to me...
    Had a smooth purchase transaction with me?
    Please share your feedback
  • jeffw
    • 1087
    just use a 17 end wrench if you can get it in t here and its not fun at all
      I use a short piece of 17mm hex that I cut from a allen wrench. Slip it into the drain plug and use a 17mm six-point box end wrench. If the plug hasn't been out recently you may need a cheater.
      • scottinAZ
        • Dec 2009
        • 1312
        I do similar to Jlevie. I have the 17mm hex bit from Vatozone, and like you its too long on the ratchet. Solution is to stick a long handled 17 box end on the hex bit and have at it. works a treat.
        I saved 15% on my Bimmer parts by switching to ...
          • 37834
          You can also drop the trans brace and you'll be able to fit the ratchet.
          Grover Beach, California
          BimmerHeads.com
          • reelizmpro
            • 9559
            17mm hex socket with 17mm open end wrench worked for me when I didn't have the proper tool. I have since ordered the "VW" trans plug tool for $3.99 from Autozone. It's a short 3/8's to 17mm hex socket.
            88 M3 - LACHSSILBER
            89 M3 - ALPINEWEISS II
            • Dsun
              • Jul 2011
              • 371
              thanks guys, i will look for this 3.99 trans plug. If not then ill try end of the wrench.
              What do you mean by "i might need a cheater" jlevie?
              • davem
                • Jun 2010
                • 705
                something to give you more leverage
                • E30_Pare
                  • 7801
                  I'm using a 17mm allen tool with my jack handle for a breaker bar.
                  DREWLIENTE
                  1$ PShops PM me
                  • AndrewBird
                    The Mad Scientist
                    • 11898
                    I made a tool by welding a nut with a 17mm hex to a cheapy 3/8" drive socket. One of the many tools I've made instead of bought.
