Clutch Lube Recommendations?
  • bmwman91
    • Oct 2004
    • 3134
    Hey guys, I was looking through the BMW service manual and it recommends lubing the TOB/release fork/pivot pin with Molykote Longterm 2 grease. It looks like the stuff is hard to come by, at least in a small tube. What do you use to lube your clutch components?
    One person that generally seems to know their stuff recommended silver anti-seize paste, although that is what I usually use on my exhaust fasteners.
    I did manage to get some Esso Unirex S2 grease for the input shaft splines, so at least that matches the service manual's recommendation.
    Transaction Feedback: LINK
    Most any grease will work for this. I use synthetic wheel bearing grease.
    • Smelser
      • Feb 2011
      • 633
      clutch lube, SURE just smear and grease all over the flywheel, to keep it well lubed. this works well when brakes SQUEAL, just smear the rotors with as much grease as you can !!!
      Seriously, Im F'N KIDDING, DO NOT ATTEMPT THAT
      sigpic1984 318i Total conversion to a DIRT race car.
      Check out our build on facebook @ www.facebook.com/brewstermotorsports
      • nrubenstein
        • 3148
        If that's the same recommendation as for the iX front driveshaft splines, Dow Corning Molykote BR2 is readily available in tubes from McMaster-Carr.
        2002 BMW M3 Alpinweiß/Black
        1999 323i GTS2 Alpinweiß
        1995 M3 Dakargelb/Black
        - S50B32/S6S420G/3.91
        1990 325is Brilliantrot/Tan
        1989 M3 Alpinweiß/Black
        • 110stx
          • Sep 2011
          • 253
          I got moly lube for clutch assembly from the parts window at a honda dealer.
          It was not cheap.
          STX e30
          No. 10/110 STX: 1989 325i
          DD: 1991 318is slicktop
          SHAZAM, GOMER, LOOK AHEAD.
          • Jaxx_
            • Dec 2009
            • 1880
            I think I used engine assembly lube...?
            • bmwman91
              • Oct 2004
              • 3134
              Thanks guys. There's a big tube of Molykote BR2 coming from McMaster, along with a bunch of other stuff I needed.
                • 34844
                yep. it's cheap, too.
