Help with replacing 260gtrag seals
  • jink0619
    • 808
    My trans is leaking from the seal where the driveshalf/guibo connects to. Can anyone help with a descriptive instruction for an average diy newbie.
    -thanks in advance
    E30love
    It is probably also leaking from the selector shaft seal.
    To pull the selector shaft seal a small hook type puller works best. To install the new seal a deep socket of the right diameter works well as a driver. The output flange nut was installed with thread locker. Heat the flange to 300-350F to break down the thread locker and use a thinwall six point socket on nut. Pull the seal and use a driver to seat the new seal. Reinstall the nut using blue Locktite.
    • noid
      • 1536
      Can both be done without dropping the transmission?
      Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
      Your resource to tools and tips: www.rtstools.com
        Yes
        • jink0619
          • 808
          Thanks for the response, so for the output seal, there is just one bolt to remove?
          E30love
            Correct just the one nut.
            • jink0619
              • 808
              update:
              I replaced the input seal, removed the 6bolts pulled out the seal and in went the new, was pretty easy. So on to the selector rod seal, pita! took me forever to get the seal out, i used a 15mm deep socket to help push the new seal in.
              As for the output seal, still looking for a 30mm thin wall socket =(
              E30love
              • 36brua
                • 689
                Originally posted by jink0619
                update:
                Maybe buy a cheep socket and grind or have it ground down to fit
                My CA legal M60 swap
                The happening in our garage
                  I found a deep thinwall socket at Advance in their special tools area.
