How do I know....
  • Mastrcruse
    • Sep 2005
    • 5340
    How do I know....
    I'm going to pull a tranny out of a pick and pull car tomorrow. Before I take it home, is there some way to tell if it is okay? Sitting in the car it shifts smoothly.
    I plan on replacing the clutch, pressure plate and getting a 323i flywheel but want to make sure I get a good tranny.
    Thanks.
    In the absence of obvious problems (noise while turning, inability to select a gear, etc) the only way to tell if a transmission is good is to install it and see if it has any problems.
    • TobyB
      • 5280
      You CAN hook a drill to it and spin it and shift it while it's spinning.
      That finds quite a few problems.
      But no, the only definitive test is to run it under load.
      Oh, draining the oil and looking at it and smelling it can
      also tell you a bit.
      t
