NON-HYPOID gear oil
  • jaydeep
    • Jun 2011
    • 208
    NON-HYPOID gear oil
    I need to change 5-spd manual transmission fluid. In owner's manual says to use NON-HYPOID fluid. I went to local part store and could not find NON-HYPOID. I know may of you are using redline. But what are other choices?
    sigpicGLETSCHERBLAU METALLIC with leather INDIGO LEDER interior and blue top.
  • nrubenstein
    • 3148
    GL4 is what you are after in the gear oil line. GL5, with the exception of a few nonstandard oils (i.e. Redline) will eat the synchros.
    But you should look at the side of the transmission and figure out whether or not it wants ATF, MTF (75w80), or 75w90. There will be a sticker there.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • jaydeep
      • Jun 2011
      • 208
      I looked and could not find any sticker. My car is 92 vert.
      • TobyB
        • 5264
        In the absence of stickers, GL4's a good guess.
        Unless red ATF came out, then you know what to do!
        But I really can't find ANY reason in the world not to use MTL from Redline.
        It just works.
        t
