Is there anyway to bypass the Guibo
    • 34844
    Pelican sells lots of "aftermarket" stuff. Generally the BMW part will cost a lot more and are often "special order".
    I'd order one from somebody like blunttech that you know is getting it straight from BMW.
      Going through guibo's that fast makes me wonder it the is a drive train alignment problem. In particular if the engine and transmission is at an angle to the the front section of the drive shaft the guibo will be under flexing stress. Assuming a stock configuration, replacing the motor and transmission mounts may help.
