m3 guys i need your help dif and tranny content
  • oliver.r
    • Mar 2012
    • 3839
    what size is the hex forthe drain plug for:
    dif
    transmission
    filler plug for:
    transmission
    dif
    any diy for both?
    found some non m ones but there seems to be a lot of contradicting info
    thanks
  • reelizmpro
    • 9558
    17mm female for both trans plugs. Honestly can't remember what the diff plugs are but it's easy to figure out once you are there. They are smaller.
    Get a decent fluid pump online and find compatible containers that will work with the pump. .99 cent store degreaser container worked well for me. It is recommended you drive the car a bit to get the fluids warm before draining but not necessary.
    Make sure you are able to break the filler plugs free first before draining your fluid. The filler plug for the trans is hard to get to and often times you cannot get a rachet in there. You can either use a 17mm Hex/allen socket with just a 17mm box wrench to turn it or you can get a special "VW transmission plug" tool from autozone for like $6. It's a short 17mm male hex adapter that will fit over a rachet.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • oliver.r
      • Mar 2012
      • 3839
      appreciate it a lot!
      • FLG
        • Sep 2011
        • 3165
        Make sure you use a hex socket on the diff plug or they will strip. If one is stripped already I've welded a nut on mine as a fix
        Sent from my Galaxy Nexus using Tapatalk 2
        -Build http://www.r3vlimited.com/board/showthread.php?t=295277
        • oliver.r
          • Mar 2012
          • 3839
          Awesome thanks
          Another question, is the front wheel hub nut 46 or 36mm?
          • oliver.r
            • Mar 2012
            • 3839
            looked up the part number and it is a 46 mm
