Decent trans mounts
  • RobE30
    • 959
    Decent trans mounts
    About 7 years ago (probably 25k miles ago) I installed IE urethane trans mounts and now they're cracked and falling apart. Is this "normal"? Any suggestions for stiffer mounts that will last longer?
    09 BMW 328xi touring 6spd
    05 Subaru Outback XT 5spd
    87 BMW 325is
    a few bicycles
    The OE mounts last far, far, longer.
    • bmwstudent
      • Sep 2011
      • 1364
      try stock E21 mounts, they are a little more stout have a larger sized bolt. They work great.
      • Cronopoulos
        • Jul 2011
        • 2187
        PM Silence via Condor Speed Shop, he will get you taken care of for a stiffer mount.
        Project log -- DIRTY 30
        2.7i * Megasquirt tuned * E85 powered
        • RobE30
          • 959
          Thanks
          87 BMW 325is
          a few bicycles
          • jaywood
            • Jul 2010
            • 4528
            OEM will work fine.
            • RobE30
              • 959
              Is there any benefit to running solid or urethane mounts over oe? The car is slowly transforming from street only to split btwn street and track and there is a chance it will become turbo'd
              87 BMW 325is
              a few bicycles
                If the car is primarily a street car that sees occasional track time I'd use OE mounts. Poly is preferred (for stiffness) on a dedicated track or race car and the life of the bushings isn't a factor there as they should be replaced every 3-4 years, along with the control arms/bushings, motor/diff mounts.
                • RobE30
                  • 959
                  Thanks Jim. Last question, use genuine BMW mounts or generic aftermarket?
                  87 BMW 325is
                  a few bicycles
                    • 37829
                    I personally use the Meyle mounts and haven't seen an issue.
                    Classic BMW Specialists
                    Grover Beach, CA
                    www.BimmerHeads.com
                      OE or those from the OEM supplier.
