CSB went bad.
  • Larzzz
    • Jan 2013
    • 531
    CSB went bad.
    My center support bearing went bad in my 91 318i. Are these hard to replace?The one i found looks pretty good and only $17
    Any info is appreciated!
    http://www.ecstuning.com/BMW-E30-318....8L/ES2091492/
    1991 318i Slicktop - Sold
    1991 325ix - Sold
    1997 Estoril M3 Coupe - Sold
    1986 325es - RIP
    1997 328is - Sold
    1995 Avus M3
    instagram @MattLarzz
    //M42 GOON-SQUAD
    http://www.r3vlimited.com/board/showthread.php?t=281596
  • vert_this
    • Feb 2012
    • 395
    you need to use a press, you will also have to get the exhaust out of the way. If you don't pull your exhaust frequently spray the fasteners with PB blaster otherwise you may have some more stuff to repair. The Center support may be bad however if you have been on it any at all you most likely need a DS. GL
    • craiggroves91
      • Oct 2009
      • 3024
      A press is not needed to change the CSB! Though it would be helpful
      1989 BMW 325i SOLD
      1998 BMW Estoril Blue e36 M3/4/5 SOLD
      1987 BMW 325 (The Piece) SOLD
      1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
      • Larzzz
        • Jan 2013
        • 531
        So i take out the DS to put it on? i redid my exhaust so thats not a problem
        1991 325ix - Sold
        1986 325es - RIP
        1997 328is - Sold
        1995 Avus M3
        //M42 GOON-SQUAD
        • YosemiteSam
          • Apr 2011
          • 1302
          Just did mine for the first time, the hardest part was getting the new one onto the driveshaft. Make sure you get all the parts needed. You will need the new CSB, backing plate, cir-clip, and maybe a new cover plate. Also, while you're down there it may be a good time to replace your guibo.
          • EatsHondas
            • Sep 2012
            • 404
            No way man, it's quite easy. Can be a PITA at times, but you don't need any specialty tools.
            1) Jack the car up
            2) Remove oxygen sensor from exhaust
            3) Jack up motor 1-2 inches at A/C bracket (gives you clearance for exhaust removal so you don't need to undo front swaybar)
            4) Remove exhaust at down-tubes (3 14mm nuts per pipe)
            5) Let exhaust hang on front sway while you unbolt the hangers on the transmission and muffler
            6) Remove exhaust
            7) Remove heatshield just in front of the differential
            8 ) Remove larger heatshield just in front of previous heat shield
            9) Put car in gear and pull e-brake
            10) Plumber's wrench on driveshaft nut (if you're underneath the car with your feet pointing towards the rear, the nut is lefty-loosey)
            11) Unbolt driveshaft at differential (4 nuts)
            12) Pry (or find another way) between the rear subframe and a driveshaft stud to collapse (shorten) the driveshaft
            13) While supporting the dangling end of the driveshaft, unbolt the center support bearing (2 14mm bolts)
            14) Unbolt driveshaft from output shaft of the transmission
            15) Remove driveshaft from car
            16) Pull the two halves of the driveshaft apart (MAKE SURE you mark the two halves so you know how to align them properly when you're reassembling the driveshaft)
            17) Remove and replace the center support bearing (look for the snap-ring against the bearing race)
            There's a lot of things to unbolt and remember, but nothing you can't handle.
            1989 325i Lachssilber Sedan
            5-Speed Swapped
            M30B35 Swapped
            MegaSquirt MS3X
            1987 325i Lachssilber Sedan
            260k OEM Automatic Daily Baby
            • Larzzz
              • Jan 2013
              • 531
              Damn. Thanks guys!!
              1991 325ix - Sold
              1986 325es - RIP
              1997 328is - Sold
              1995 Avus M3
              //M42 GOON-SQUAD
              • YosemiteSam
                • Apr 2011
                • 1302
                Originally posted by EatsHondas
                17) Remove and replace the cener support bearing (look for the snap-ring against the bearing race)
                It's not actually up against the race, the cover plate should be in between the cir-clip and the race.
                • craiggroves91
                  • Oct 2009
                  • 3024
                  I forgot the plate and circlip on my e36 m3 shaft, no problems.
                  Maybe one day I'll get them on
                  1989 BMW 325i SOLD
                  • Hick
                    • Sep 2005
                    • 6451
                    Make sure you mark it before taking the DS apart. It's balanced you know!
                    Originally posted by vlad
                      In almost all cases a failure of the CSB will be caused by bad/binding u-joints in the drive shaft. Unless both the drive shaft and CSB are replaced at the same time, the new CSB will probably have a short life.
                      • Killacortes
                        • 1937
                        True Story
                        r3v does not fuck around. First you get banned, then they shoot you
                        • vert_this
                          • Feb 2012
                          • 395
                          U may want to look for a new DS.
                          If you do buy a new one (DS) get one that has rebuildable u joints. I think the last one I bought was like $350 but its been like 10years tho.
                          If u insist on just replacing the CSB you can pull the DS and take it out to somewhere like NAPA (with machine shop). They can press the old one off and put the new one on for like $10-$15 bucks.
                          • Threehz
                            • 1480
                            Job is pretty simple all in all. Just make sure you mark DS before separating and PUT THE CSB ON THE CORRECT WAY.
                            I put my CSB on backwards after triple-checking it was right, ended up destroying the race trying to remove it backwards and had to buy a another CSB 7__7
                            Different strokes for different folks.
                            • Chriskbmx
                              • Apr 2012
                              • 972
                              does anyone have a picture of what the right way is? i made a mental note to remember how the other came off and forgot lol.
