Getting rid of the e-torx bolts?
  • 96Formula6spd
    • Feb 2013
    • 96
    Hey I was wondering if anyone has replaced any of the e torx bolts with regular ones. I am going to be swapping transmissions in my car and the bolts I pulled for the junkyard transmission are kinda beat up and rusty. The ones on the car now look even worse. So anyone know if swapping to a standard head bolt would work? If so anybody have the sizes you need to do it?
    1987 325is- $700 project car
    1996 Pontiac Firebird Formula - Bolt ons,cam, 6 speed of fun.
    2001 Miata - Current DD and to be for sale soon.
    The Build- http://www.r3vlimited.com/board/showthread.php?t=281011
    Parts Car Part Out Left Overs- http://www.r3vlimited.com/board/show...21#post3860521
  • EatsHondas
    • Sep 2012
    • 404
    Torx-head bolts are used because they can take much more torque than standard hex-head bolts. The star shaped head is much stronger. Torx bolts also fit perfectly onto their corresponding sockets. Hex always has a certain degree of slop between the head and the socket/wrench.
    Since you need a few feet of extensions and possibly a u-joint to install/pull the transmission, the risk of stripping the bolts is much higher if you're not careful. I personally would not swap to hex. Get new torx bolts if your current ones are beat up.
    1989 325i Lachssilber Sedan
    5-Speed Swapped
    M30B35 Swapped
    MegaSquirt MS3X
    1987 325i Lachssilber Sedan
    260k OEM Automatic Daily Baby
    • 5Toes
      • 9836
      I did it because I lost one
      it worked fine - got it from Lowes
      • ForcedFirebird
        • Feb 2007
        • 8300
        They are only a few more dollars to buy new external Torx bolts than to use regular hex heads. It's very difficult to get a hex socket on the bolts if separating the engine/trans in the car.
        john@m20guru.com
        Links:
          A complete set of new e-torx bolts for the transmission isn't going to "break the bank". If plain hex head bolts would have been satisfactory, BMW would have used them as e-torx cost a touch more.
            • 37829
            Just run the correct bolts. Look up the part numbers on RealOEM.
            Classic BMW Specialists
            Grover Beach, CA
            www.BimmerHeads.com
