89 525i manual tranny question
  • deeze30
    • May 2013
    • 298
    Okay so this guy is selling his manual tranny from his 89 525i for a decent price, including everything needed pedal assembly, drivetrain, clutch etc but i have a 89 325i. would this fit? Seller claims it will but i just wanted to check here if it would? By the way my 325 is automatic if that helps at all. thanks!
    • 37832
    The only thing that will work is the transmission, flywheel, clutch.
    Pedals, shifter, driveshaft are all totally different.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • deeze30
      • May 2013
      • 298
      It's that much different? That sucks..
      • deeze30
        • May 2013
        • 298
        What other parts exactly would i need? Mounting of tranny should be fine right? Just pedals, shifter and driveshaft then? Everything else from e34 should be fine i'm assuming?
          • 37832
          I just told you the ONLY things from the E34 that will work are the trans, clutch, and flywheel.
          Every other thing needs to be from an E30. The parts are easy to source and relatively cheap.
          Grover Beach, CA
          www.BimmerHeads.com
          • deeze30
            • May 2013
            • 298
            Ok fine but how bout a 94 325i swap? Would that fit? I found a set.
            • jeffnhiscars
              • Jun 2011
              • 6011
              His answer seems crystal clear and is not likely to change by asking again.
              Just sayin'
              Alice the Time Capsule
