Is there any difference in axle shafts?
  • Rainydays
    • Jun 2013
    • 145
    I recently found a guy who'd be willing to sell me a couple axle shafts for pretty cheap. I actually just finished rebuilding my own, but I'm thinking of buying them so I could clean/rebuild and sell them to help fund my own project. So I want to know if there's any differences between the years and models before I go for it, and also what people think I could sell them for. I'd basically be cleaning the inner joint in a parts cleaner, cleaning out the outer as best I could, repacking them with new grease, and reassembling them with new boots after I've closely inspected the joints and shafts for defects.
  • JinormusJ
    • 6887
    AFAIK
    Only iXes has specific axles, and that may or may not be in the rear. All e30s were equip with the same axles stock; while there may be differences in build quality year to year, the input shaft, hub shaft, spline count, spline width, length; essentially all critical components will be the same
    • Danny
      • 14216
      Just make sure they are straight. Also that they are not bent.
      • Rainydays
        • Jun 2013
        • 145
        AFAIK
        Thanks, that clears things up. Any advice on pricing, or whether or not people would want them? I just figure since it's a pain in the ass to do yourself, people might be willing to pay for a finished axle.
        • Danny
          • 14216
          I would charge between 1 and 500 dollars.
          • JinormusJ
            • 6887
            IIRC
            There was a member here selling reman'd axle shafts for $350 a pair with a $50 core refund. But he knew his business, was a mechanic for a while, and warrantied his stock
            They are a pain, but many will do the job themselves; you'll always find a few who'd rather pay to have it done though
            • Rainydays
              • Jun 2013
              • 145
              Enough to make a profit then. Thanks for the help.
              IIRC
              Ya, I don't think I could justify charging that much as an amateur who couldn't offer a warranty. Do you think somewhere between 180-250 would be a fair price for a pair done under those circumstances if I photographed the process?
              • Danny
                • 14216
                Whatever price you charge I will charge a dollar less.
                • JinormusJ
                  • 6887
                  I can't give you your opinion
                  That is for you to decide what you feel comfortable charging for your services
                  • Rainydays
                    • Jun 2013
                    • 145
                    Thanks for the help then guys. It's good to know that it could at least be worth trying. Didn't want to jump the gun and do it just to find out a refurbed axle isn't worth anything.
                    • Danny
                      • 14216
                      I'll be watching.
                        • 34844
                        AFAIK
                        Non airbag axles aren't the same, the hubs are different.
                        • Holland
                          • Nov 2008
                          • 7212
                          ABS cars and 85 and earlier are different. I tried putting the beefier 325 axles on my 85 and they physically do not fit. The splined end is a different shape. The post 85 axles are more squared off where the ABS ring is while the earlier axles are rounded.
                          Originally posted by DEV0 E30
                          • JinormusJ
                            • 6887
                            Looks like I have just about as much research to do as OP
                            • Rainydays
                              • Jun 2013
                              • 145
                              Hmm, good thing I asked.
