Originally posted by aTron12
View Post
shaving a flywheel
Moving sale: Everything Must Go!
FS: 2001 740iL Sport, low mileage..... SOLD
FS: 1990 Mtec II 325iS, $12,0K OVNO
FS: 2003 Honda Odyssey EX-L Navi..... SOLD
FS: New Rieger lip, lachsilber metallic (WILL INCLUDE W/e30!!)
FS: Very rare, new lachsilber metallic E30 Aero pack sideskirts... (WILL INCLUDE W/e30!!)
Extreme 325iS (well, slowly getting there, anyway)......
Almost too many mods to list ;-)
Originally posted by Wh33lhop View PostWhy stop at 15? Mine's at about 12-13lbs, I've noticed zero decrease in drivability.
Just being thorough here because I want to do it right the first time!
As I mentioned, I think ~12lbs is fine with a stock cam, it's only when you start doing other things that mess with the idle that you're likely to start running into problems.Moving sale: Everything Must Go!
Originally posted by aTron12 View PostSo, you are running a stock clutch etc, had your flywheel shaved down to 12-13lbs and no negative effects at all? Your idle is fine?
Honestly, I'd rather have a lightweight flywheel with a lumpy idle and a cam than a regular-weight flywheel. You may be able to adjust your idle speed as well, depending on how you're tuning it.paint sucks
Nice... I still haven't got around to putting in a short shift kit...Moving sale: Everything Must Go!
Anyone know if you can still shave the flywheel the same for an m42 with the m20 clutch/flywheel swap? I'm replacing my tranny on the m42 and thought I might as well go through with the swap... and if I'm doing the swap why not go ahead and shave it down too? Anyone have an extra one laying around btw?
Drove my car around today after having the new clutch/shaved flywheel installed. The machinist shaved it down to 14LBS. He didn't feel comfortable taking it any further. I gotta say it made a really noticeable difference. The throttle response is much smoother and takes less effort to get those R3V's up. No issues with idle at all.. like not even a slight change. Drives the way a BMW should! We also installed a Z3 1.9 shifter which is a really nice addition to the experience. Slides right into gear perfectly and has a really nice tightness & quicker throw. Thanks for the advice...
Glad you're happy... I know I was when I had it shaved!
I still gotta do the Z3 shifter though.....Moving sale: Everything Must Go!
