shaving a flywheel
  • Digitalwave
    is a poseur
    • 6293
    The average shaved M20 flywheel goes from 19-20 lbs to down to 13-15 lbs. The difference of 5-6lbs is VERY noticable, as it would be in the 5-6lbs additional difference from a shaved M20 flywheel to an aluminum one.
    RISING EDGE
    • sweetride01
      • Apr 2004
      • 713
      Is it somewhat comparable to adding hp?
      Moving sale: Everything Must Go!
      FS: 2001 740iL Sport, low mileage..... SOLD
      FS: 1990 Mtec II 325iS, $12,0K OVNO
      FS: 2003 Honda Odyssey EX-L Navi..... SOLD
      FS: New Rieger lip, lachsilber metallic (WILL INCLUDE W/e30!!)
      FS: Very rare, new lachsilber metallic E30 Aero pack sideskirts... (WILL INCLUDE W/e30!!)
      Extreme 325iS (well, slowly getting there, anyway)......
      Almost too many mods to list ;-)
      • Digitalwave
        is a poseur
        • 6293
        You could say that, since you are minimizing driveline loss.
        RISING EDGE
        • MrK
          • Jan 2006
          • 709
          How about just swapping the flywheel for one from an e21? Anyone know if that would work?
          This is your M20 on steroids:
          • Berlin
            • Apr 2006
            • 5
            what about m42 flywheels
            • AdironRider
              • Dec 2004
              • 3491
              M42 flywheels are the heavist at almost 28 lbs. You can swap in a m20 flywheel/ clutch and modify the starter and you should be money.
              Back to my roots
              • ACHTUNG
                • May 2005
                • 2397
                I just had aprox. 5lbs removed from my flywheel. It weighs aprox. 13lbs now.
                1989 US E30 Cammed S52
                Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
                • Ali//325i
                  • Jul 2005
                  • 270
                  Ya My flywheel comes in at 12 lbs exaclty and was balanced and resurfaced at the shop i took it to. I could have gone lower but he said he wanted to keep it streetable at 12. My car runs great and i never have to use the brakes around town. They sent me a dual mass flywheel when i ordered it and i ended up getting it lightened, balanced, and resurfaced for less than it cost to buy a brand new flywheel.
                  -Ali
                  • aTron12
                    • Nov 2009
                    • 98
                    A little late here.. would you guys say that 15lbs is a good, safe weight to aim for? I am going to have this done next week since my flywheel is going to a machinist anyway.
                    • idanity
                      • Jun 2006
                      • 775
                      12 is the sweet spot for steel flywheels.
                      and the disc side
                      lets also talk about minimum thickness
                      4cyl. engines
                      84-85 = 23.5mm (.925 in)
                      6 cyl. engines
                      1984 = 25.0 mm (.984 inches)
                      1985-1990 = 32.0mm (1.26o inches)
                      open the Bentley to section 4 and page 58 to see the "a-step" cut (flange height)
                      weight can be ultra light, but remember to consider the warping.
                      steel is more durable than alloy, but my rule of thumb (or writs) is
                      never machine a flywheel thinner than the pressure plate (which would be hard to do)
                      when they machine it, also request all edges be rounded out.
                      also ask about the flange height (if they know, bmw doesn't specify what would reduce pedal throw to the point of not ever releasing the disc, and to perfectly release it at its minimal throw)
                      this is where experience comes into play.
                      ask you local track.
                      luckily, when i brought mine in, i already asked around, called around,and when i deliverd the f.w. i found 5 different posters of e30s...
                      thats a score.
                      to add.
                      if you can afford it, have your p.plate balanced to your flywheel when its all done.
                      they will have to mark both f.w.and p.plate so you can re-align them when you install it. but its worth it.
                      have fun.
                      3 pedal club
                      200,k+ club
                      cabrio club
                      port-matched- polished- purring www.BMWpark.org
                      </div>
                      linux since 1999
                      • idanity
                        • Jun 2006
                        • 775
                        iwoops, didn't realize this thread was ressurected from almost 20000years ago.
                        3 pedal club
                        200,k+ club
                        cabrio club
                        </div>
                        linux since 1999
                        • sweetride01
                          • Apr 2004
                          • 713
                          Haha, it seems so.
                          I got mine taken down to about 12 pounds, it's great now. Revvs so quickly :-D
                          • aTron12
                            • Nov 2009
                            • 98
                            Any negatives from going down to 12lbs? I have read that it is possible to throw one's idle off if the flywheel is shaved down too much. I'm thinking about going to 15lbs unless anyone thinks I should just go for lighter. I drive an '88 325is--daily driver. Thanks!
                            • sweetride01
                              • Apr 2004
                              • 713
                              Yes, it does make the idle a little less predictable. In fact, with my Jim C chip and Schrick 284/272 cam, the idle is quite rough, and if I run with the AC on, the car can stall when I depress the clutch (the revs drop too quickly). But I'm sure that with a stock cam, this would not be a problem.
                              • aTron12
                                • Nov 2009
                                • 98
                                That is helpful. So maybe I will stay at 15lbs in hopes of finding a good balance between performance and stability. I am running a stock cam...
