shaving a flywheel
I'm about to have this done too.
I'm wondering if anyone has an idea of what the step is for on the clutch side of the fw. I measured it this morning and it's only .010" which seems basically negligible compared to the overall thickness of the flywheel. Does this .010" really make a difference and why?
Also, should I remove the 3 dowel pins from the fw before taking it to the machinist, or will they do this?
thanks,sigpicComment
What should I specify to have the flywheel reduced to 12-13lb? The flywheel thickness is already at 32mm (and it weighs 20lb now), so I don't see a way of removing any material from the clutch side, and the machinist I'm working with estimated that you could only remove about 3-4 lb from the crank side.
Any advice is greatly appreciated, as this car is my DD and my only vehicle, so I would like to get it on the road again asap. Thanks!sigpicComment
