Will a m52 work with my tranny?
  • ThatOneEuroE30
    • Dec 2013
    • 8626
    I'm planning on swaping a m52 into my 84 320i. It has a getrag 265 5 speed I was wondering if I could bolt a m52 up to it?
    1991 318i 4dr slick top
    Mtech 2 turbo restoration
  • LJ851
    • 7918
    Why does your car have a 265 in it ? It did not come that way from the factory.
    Lorin
    The M30 is God's engine.
    • Hooffenstein HD
      • Nov 2012
      • 1388
      Your car should have a Getrag 240/242.
      • ThatOneEuroE30
        • Dec 2013
        • 8626
        I'm going by the specs I found on the internet. What should it have in it?http://www.automobile-catalog.com/ca.../bmw_320i.html
        I go my info from link above.
        • e30austin
          • 15382
          Definitely shouldn't have an G265.
          A 260 or 265 will work with the proper shifting/driveline parts, though.
          • Hooffenstein HD
            • Nov 2012
            • 1388
            What should it have in it.
            • TobyB
              • 5242
              the 240 will not, though.
              t
              • Hooffenstein HD
                • Nov 2012
                • 1388
                t
                Why wouldn't it? It's already attached to an M20, so everything will be exactly the same as using an M20 260 on an M5*.
                • ThatOneEuroE30
                  • Dec 2013
                  • 8626
                  How would I tell what my car has instead of going off the internet?
                    Get under the car and find the part number on the transmission. On a getrag 260 it is on the left side of the bell housing.
                    • Hooffenstein HD
                      • Nov 2012
                      • 1388
                      Either way, it doesn't matter. If it's attached to an M20 you can bolt it to an M52. Use your original flywheel, clutch and starter motor. To compensate for the rotated bolt pattern, use a garagistic trans swap brace and bend your sheet metal shifter carrier, or attach it to the floor.
                      • LJ851
                        • 7918
                        Where does OP say his car has a M20?
                        A 1984 320i would be a M10 car.
                        Lorin
                        • Hooffenstein HD
                          • Nov 2012
                          • 1388
                          Nope. Not unless it's had an engine swap. M20B20 is what it should have.
                          • LJ851
                            • 7918
                            You are correct, my mistake.
                            Lorin
                            • e30austin
                              • 15382
                              Regardless, it shouldn't have a 265......
