HARD vibration from the rear...
  • W1ccaboy
    • 61
    Whenever I accelerate I get an incredible vibration from the rear between 18mph-22mph. This range will increase if I am accelerating harder or going up steep hills, and will not shake at all if I barely use any gas to get past that range. I'm thinking rear wheel bearings? I do have the wheel bearing hum so I know they need to be replaced.
  • kronus
    • Apr 2008
    • 13032
    check if your CV's have lost grease and are disassembling themselves, check that your diff's still attached, and check that your CSB is intact. I'd suspect all of those before the wheel bearings.
    cars beep boop
      That sound most like a failed center support bearing and binding u-joints in the drive shaft. Replacement of the drive shaft and a new CSB is the fix.
      • Sea Aych
        • Apr 2013
        • 764
        I don't think it'll be your wheel bearings unless you hear some whining as well (something like two metal plates spinning flat against each other).
        I'm siding with jlevie on the CSB and the DS u-joints
        1988 Atlantisblau Euro/Japanese 325i Cabriolet
        1989 Schwartz 325i - now M50 powered! - now very dead
        1998 Toyota 4Runner Limited
        My 17,000km Big NA National Parks trip!
        • ME30W
          • Feb 2012
          • 811
          I had a similar issue, immediately thought it was my CSB, ended up being that my exhaust was secured too tightly, and would rattle like crazy on the undercarriage at certian RPM's
          I like cats.
          • mathillois
            • Sep 2012
            • 71
            i replaced the cbs and guibo and i get a slight vibration only from 25-28mpg. anyone have an idea of what it can be?
            • W1ccaboy
              • 61
              Definitely not related to RPM in my case. This will happen in any gear and only at those speeds. I bought a new CSB just haven't installed it yet.
              Sent from my DROID RAZR using Tapatalk
