Odd clutch issue
  • peterpeter
    • Apr 2014
    • 21
    Odd clutch issue
    Hey everyone, I replaced my clutch a few weeks ago and put about 1000 miles on it with no issues. I then did a small trip from Boise, Idaho to Denver, Colorado area. Halfway through the trip I noticed that my clutch felt weird (this was when I was driving through town and actually shifting.) It would engage lower than usual and with each press of it it would drop further, to the point of where the actual pedal range was only a few inches, if even that.
    The clutch still engages fine, but the actual point where it goes from disengaged to engaged is very small. Could that be the slave cylinder? It also seems to go on and off with the issue, I pushed it multiple times in and out and it seemed to firm up, but then it went back to a very short range. The pedal will spring back up mostly on it's own,, sometimes with a bit of help, so doesn't that rule out the master cylinder? It's all free play with no pressure from that point on though. I just don't want my clutch to have more issues since I need my car running well. Thanks.
    That sounds like a failing master cylinder. If of the same age, replace the master, slave, and soft line.
    • peterpeter
      • Apr 2014
      • 21
      Okay, I'll get on that soon. How come it seems to be intermittent though? Sometimes it will be really soft and makes it difficult to drive, while other times it does seem to work okay..
      • Sea Aych
        • Apr 2013
        • 767
        Definitely not slave cylinder - if that goes your pedal would be on the floor
        1988 Atlantisblau Euro/Japanese 325i Cabrio
        1989 Schwartz 325i - now M50 powered! - now very dead
        1998 Toyota 4Runner Limited - gone
        My 17,000km Big NA National Parks trip!
