Driveshaft question
  • mathillois
    • Sep 2012
    • 71
    Driveshaft question
    So my driveshaft is unbalanced... Which is awesome. Idk if I want to spend $1000 on rebuilding it and cost of labor (since my living arrangements have recently changed). I do want to engine swap in the future when my living situation is more stable and I can actually work on my car. So my question is should I jut wait (while my car slowly deteriorates) or should I just suck it up and put the money into it now while sparing some parts from damage.
    Looking to go m5x in the future, if I were to use a zf transmission could use an e30 driveshaft or would I have to convert the rest of rear drivetrain to e36?
    I was also thinking of just pulling one out at a pick n pull and just hope that it's not messed up. It'll still cost since a shop would do it but it would be way more of a budget thing.
    I see my options, I'm just not sure which one is best for the long run. Just hoping for some input on my situation.
  • AwakenNoMore
    • Dec 2010
    • 1291
    junkyard is a gamble, sometimes you luck out, i found a rebuilt one and walked out paying $35 including the heat shield and crossmember. So you should go for it
    1991 325i - "Scambles" The Daily Driven lightly modded.
    1988 Mazda RX-7 TII "Mako" The Free Dorito
    bacon by Jared Laabs, on Flickr
    • redlightpete
      • Mar 2012
      • 266
      My $60 eBay driveshaft felt a bit notchy but it's working fine. They shouldn't really go out of balance unless one of the weights comes off or a u-joint is bad, so you might be able to inspect it to some degree.
      • mathillois
        • Sep 2012
        • 71
        That sounds like your paying the scrap value for that driveshaft. Haha did you buy off an individual used?
        I'm thinking of pick n pull unless I hear otherwise
        • AwakenNoMore
          • Dec 2010
          • 1291
          i'm saying i found my rebuilt unit in the junkyard, i got lucky. Some are good, some are shit, since the cars dont drive you dont really know
          • Dallin97
            • Mar 2014
            • 59
            Replacement BMW Drive Shaft with new U-joints, CV joint and center support. Our BMW Driveshaft is balanced at 3500 RPM and includes free shipping & warranty
            1990 325i sedan Turbo project.
