wtf happened to my friends trans
  • sam_
    • May 2014
    • 630
    hey all,
    so my friend has a 87 325is auto and one day his trans just took a sh*t. it has no power in any gear and top speed is prob 5 mph. only lead that we have is there is ATF exploding out and dripping whenever the car is turned on
    check out the pics !
    1991 325i
    flickr
    @sambhaskins
  • ThatOneEuroE30
    • Dec 2013
    • 8626
    Ahh see the problem is that automatics are shit so the only proper way to fix it is with a 5 spd swap or a very large stick of dynamite.
    But in all seriousness that tranny is toast
    1991 318i 4dr slick top
    Mtech 2 turbo restoration
    • James Crivellone
      Head Janitor
      • 6305
      How is it toast? If it has next to no fluid in it she aint gunna move!
      You probably have a severed transmission cooling line which connects to the radiator, or the radiator itself is leaking.
      Fix the hose/radiator, refill it, and assuming you didn't beat it up that much with no fluid it should be okay.
      • ThatOneEuroE30
        • Dec 2013
        • 8626
        Tis true Unless he was driving when it blew or tried to drive it.
        • sam_
          • May 2014
          • 630
          it blew in a drive thru and he pushed it home...only time it's been driven was in an out of one driveway lol
          and yea it's a bummer bc he got an auto to use while he saved up for a 5 spd swap and then this happened
          1991 325i
          flickr
          @sambhaskins
          • smooth
            • Apr 2005
            • 1940
            I have a 320 trans that I can sell. I'll be driving through LA next week and can drop it off.
            Das ist nicht nur nicht richtig, es ist nicht einmal falsch!
            • McGyver
              • 4636
              it's probably fine. Just find the leak, replace the hose, fill using the trans fluid dipstick tube, then keep on driving.
              • slammin.e28
                שמע ישראל
                • 12054
                My Rover (4hp22, same trans as you) has popped a line on several occasions, pumped all the fluid out, while going down the highway. Fixed it, refilled, and it still drives fine.
                • CaspR
                  • Apr 2012
                  • 3
                  It is my car, and it happened late one night (hence the need for a drive through pit stop.) And I was a block from home and just pushed the car back into my place. It hasn't moved since so I haven't tried to drive on it. I just want to makensure that this is the line that I should replace http://www.fcpeuro.com/products/bmw-...es-17221177654
                  • LateralSage
                    • May 2014
                    • 18
                    Hahaha that is worth a signature.
                    • TurboJake
                      • 3780
                      Well, pull the leaky hose and find out. There's a few. there is no way for us to know on these ends of the planets..
                      MUCH more dramatic than just plain ol' dynamite.
                      I prefer to wrap a 4lbs of ANFO around a lb of binary, and shoot it with a 7.62x54r round. I mean, it's 3 ingredients for the explosive pair. (Ammonium nitrate (For both), Aluminum(Binary), and #2 fuel oil(ANFO, the other binary)) :)
                      Leave Me Transaction Feedback
                      • ThatOneEuroE30
                        • Dec 2013
                        • 8626
                        Screw 4 let's do 25
                        • TurboJake
                          • 3780
                          Screw 4 let's do 25
                          I'm game. Bring a trans up.
                          • ThatOneEuroE30
                            • Dec 2013
                            • 8626
                            Lol if only you were closer I'd do it in a heart beat. I got family with about 1000 acres of land we could make a big boom and not get bothered one bit haha
                            • TurboJake
                              • 3780
                              I just might have to add you to the "Potentially handy people to get to know on a first name basis" list. Which is the precursor to the "Handy people to know on a first name basis" list. Which is the precursor to........
                              Etc.
