1985 325e strange behavior getting into 1st
  • sam_
    • May 2014
    • 630
    hi there,
    as i was driving around LA today with lots of stop and go driving i noticed that my car was requiring more revs to get in first and letting off the clutch made the car jutter quite a lot...could anyone help me diagnose pls
    1991 325i
    flickr
    @sambhaskins
    I suspect that what you are trying to tell us is that more engine speed than normal is needed in first gear from a stop. That and the judder is most likely a worn out and slipping clutch.
    • sam_
      • May 2014
      • 630
      given the fact that this happens under certain driving circumstances leads me to think it might be something else? is there a method for me to test the clutch
      1991 325i
      flickr
      @sambhaskins
      • sam_
        • May 2014
        • 630
        pls help anyone :(((
        1991 325i
        flickr
        @sambhaskins
        • sam_
          • May 2014
          • 630
          what about a trans fluid change!? idk when the PO did the last one..maybe this would fix the issues?
          1991 325i
          flickr
          @sambhaskins
            One check for a slipping clutch is to put the car in 5th gear at a stop and ease off the clutch. If the engine doesn't stall easily, the clutch is slipping. Of course, getting the opinion of a pro is always a good idea.
            The transmission fluid (on a manual transmission) has nothing to do with this.
            • sam_
              • May 2014
              • 630
              bump bc still have no idea what it is
              1991 325i
              flickr
              @sambhaskins
              • 2mAn
                Señior Mod
                • 21094
                Have you tried what jlevie suggested? He is a pro
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                Make R3V Great Again -2020
                • Wanganstyle
                  • 2828
                  Originally posted by smhskns
                  hi there,
                  Check your master cylinder for a loss of pressure; if its going there may be fluid by the clutch pedal area.
                  also check the slave cylinder; if either are going out it will be difficult to operate the clutch
                  • sam_
                    • May 2014
                    • 630
                    how do I check?
                    1991 325i
                    flickr
                    @sambhaskins
                    • Wanganstyle
                      • 2828
                      Hire a friend to pump the master and you watch to see if the slave is moving enough to disengage the clutch
                      • sam_
                        • May 2014
                        • 630
                        great. thanks! where are the two cylinders located ?
                        1991 325i
                        flickr
                        @sambhaskins
                        • Wanganstyle
                          • 2828
                          google.com
                          try to use this thing called a search engine; its excellent for improving IQ
                          Purchasing a thing called a "service manual" would be a very smart idea also; your car will probably need work everywhere
                          there is this other website called amazon that sells books
