Drive shaft taken apart without being marked
  • FireFight
    • Mar 2012
    • 1367
    I finally got a drive shaft I have been looking for for awhile now from a gentleman off here but when I went to grab it he had already took it apart with out marking it. Any way I can tell whitch way it went?
    I'm really stressed that I just paid a chuck of change for scrap metal
    WTB:m60b40 in PNW
    Zachary Ripley
    85 318i M50B25tu.
    92 525it 5 speed.
    80 244gl (m60 prepping).
  • FLG
    • Sep 2011
    • 3165
    Mine came apart I've thrown it together and it's been drifted on ever since being beat to crap behind 300+ hp with no issues or vibrations.
    Sent from my SCH-I545 using Tapatalk 2
    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
    • LJ851
      • 7919
      U joints line up so there really is only two ways it could have been assembled, although on a bmw shaft it doesn't make that much difference since only the rear joint sees an angle and it is very slight.
      Lorin
      The M30 is God's engine.
      • FireFight
        • Mar 2012
        • 1367
        Prefect. That's good enough for me
        WTB:m60b40 in PNW
        Zachary Ripley
        85 318i M50B25tu.
        92 525it 5 speed.
        • LJ851
          • 7919
          You could always get it balanced if it proves to be an issue. You have a great driveline shop that does 2 piece driveshafts local, Driveline Service of Portland.
          Lorin
          • FireFight
            • Mar 2012
            • 1367
            They wanted $300 for it. They said they could only provide me a rebuilt one
            WTB:m60b40 in PNW
            Zachary Ripley
            85 318i M50B25tu.
            92 525it 5 speed.
            • redlightpete
              • Mar 2012
              • 265
              In my experience there are what look like factory paint dots on each side of the slip joint. They are yellow or white and about 5 mm diameter.
              • Coupelx
                • Oct 2013
                • 169
                The yokes need to mirror each other. If you look at a pic of an assembled one you will see what I mean. This is because the drive shaft actually speeds up and slows down as it spins. Spicer had a really cool video of this floating around. It also showed why joint angles needed to be the same for smooth operation
                • Wanganstyle
                  • 2828
                  Clean it ; there should be a white dot on each side for alignment if its an original BMW untouched driveshaft.
                  • KIRIEIW
                    • Dec 2012
                    • 3385
                    This, I just removed one today. Maybe yours wore off a bit OP? Has to still be marked a little unless the seller took it off with paint thinner or something
                    1992 e34 Touring- S50 Swap
                    1992 325i-S50 Swap (SOLD)
                    1991
