Transmission Questions
  • KIRIEIW
    • Dec 2012
    • 3385
    Hey guys, So I'm getting a automatic e30 for a more then great price but it needs a transmission. Today me and my Pops went to the junker and we picked up a manual tranny for his current auto car, he's going to convert it. That being said, we'll have this extra automatic tranny laying around and the plan is to put it in the cheap car I'm getting.
    Specs:
    1990 Convertible Auto> converting to manual
    1986 325e> Needs auto tranny because current is shot
    Is there any differences between the 2 cars transmissions or am I going to have a direct bolt on change over?
    Thanks!
    1992 e34 Touring- S50 Swap
    1992 325i-S50 Swap (SOLD)
    1991
    • 37832
    The biggest difference is the Eta cars have 2 holes in the bellhousing for the crank sensors.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • KIRIEIW
      • Dec 2012
      • 3385
      Thanks for the info
      1991
      • jeffnhiscars
        • Jun 2011
        • 6011
        The torque converters are also different due to the diffent vehicle weight but I'm not sure how significant that will be the shift points may be. If you have the option to keep the original TC that would be better.
        Alice the Time Capsule
        • KIRIEIW
          • Dec 2012
          • 3385
          So use the original from my dad's car or from the car in getting? I can drill and tap the CPS in place so that not a problem.
          1991
          • Madhatter
            • Oct 2004
            • 966
            does his vert have the 4 speed sport auto with the switch?
            Just a little project im working on
            - http://www.lse30.com -
            • KIRIEIW
              • Dec 2012
              • 3385
              Nope, just a normal crappy auto
              1991
              • jeffnhiscars
                • Jun 2011
                • 6011
                You only say that your eta trans is "shot" which doesn't say what the issue is or if you can even drive it to test the existing TC. ASSUMING your eta's torque converter is ok, then yes keep it with the car. Again, I can't say how much difference a Cabrio TC will make in an eta but I also don't want to suggest you reinstall a questionable TC. It's your call.
                • Madhatter
                  • Oct 2004
                  • 966
                  it'll be fine then.
                  • KIRIEIW
                    • Dec 2012
                    • 3385
                    Has someone used a 325i torque converter on a 325e here before?
                    1991
