Originally posted by HennaE30
View Post
Cant Find 1st or 2nd
sigpic87 325E The Honey Badger
I do believe you have a shifter problem if it's touching the shifter bezel but if you can get it into reverse you should be able to get it into 1st and 2nd gear.
If you couldn't get it into 1 and 2 when the car was off I would say it would be something to do with 1/2 shift fork but you can so...I'm at a loss.
Sent from my 831C using Tapatalksigpic
Rebuilding since 07/06/2016
Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
Poorboyz Feedback Thread
Originally posted by Poorboyz View PostI do believe you have a shifter problem if it's touching the shifter bezel but if you can get it into reverse you should be able to get it into 1st and 2nd gear.
Sent from my 831C using Tapatalksigpic87 325E The Honey Badger
Ok, so it doesn't matter if the car is on or off...it still doesn't go into 1st or 2nd?
Originally posted by Bullhead View PostNo it doesn't matter, so I know it's not the syncro's. The forks are pretty beefy in these trannys idk how you could bend them unless you Conan'd then in or something lol.
The "e" forks are weaker than the "i" ones.. The fork in my old trans was bent... I had a very similar issue to you. My bushings were so shot that reverse was like between your legs, and 2nd was damn near impossible. I would get the car on stands and take some pictures so we can help you diagnose your problem.
Sent from my iPhone using TapatalkOriginally posted by flyboyxhow about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?Originally posted by Northernbeer is my new liver cleanse.
Henna - '84 Hennarot 325e
Lola - '89 Schwarz 325is - being saved
Christine - '88 Schwarz 325is - Spec E30 Racecar
'01 White F150 Lariat 4x4 Supercrew - Daily
Dad's '05 Interlagosblau M3
Originally posted by Bullhead View PostNo it doesn't matter, so I know it's not the syncro's. The forks are pretty beefy in these trannys idk how you could bend them unless you Conan'd then in or something lol.sigpic
Thanks for the replies. If it is stuck can I take a small (and I mean the little bitty) dead blow hammer and give it a couple taps to see what happens? I will take pics as well, thanks again. And I mean to tap on the linkage at the tranny with the shifter off of it. I will try to get the shifter out and and try to actuate 1st and 2nd manually before I start the "just tap it in" goodness.sigpic87 325E The Honey Badger
Originally posted by Poorboyz View PostOk, so what I'm thinking is that the 1/2 shift fork is stuck, not bent. I've had the G260 apart a few times and am pretty familiar with it. Unfortunately you will have to split the case open to see for sure what is going on.
Good point.. Never thought about it being stuck. OP I think you have enough info to know where to start. Definitely take pictures though, like they say, a picture is worth a thousand words. And we will try to help you the best we can.
Originally posted by cunninglinguist View PostI don't believe there is a difference, as there is no "e" or "i" -specific transmission.
I thought there was? Atleast from 85+ were different than 84, thought that they beefed up the forks and syncros later on? Could be wrong, probably am.
Originally posted by Liquidity View PostWhy would the shift forks be weaker on the e? The e makes more torque than the i so if anything, the transmission would be stronger, not weaker.
It was something I thought I read somewhere..Lol don't listen to me
