Potential differential problem, help me figure it out - please and thank you.
  • tuddy
    • Feb 2014
    • 99
    The issue: when taking hard right turns or trying to slide, the car violently "hops". It feels forcewise as if i was pulsing the throttle foot off to floored. The car jerks pretty hard.
    The otherday when trying to exit a steep driveway at a serious angle my right wheel was elevated and the car would not go anywhere as if something was binding.
    Inspection of cv boots shows no rips or tears. Free of cv grease.
    There is no audible issue coming from the rear end. No clicking when turning.
    Fresh fluid
    PO says its a 3.9 diff and is NOT welded.
    Car hooks both wheels in a straight line.
    Bc racing coilovers set to full soft, upgraded rsb.
    What say you r3v?
  • TobyB
    • 5298
    If you lift one driving wheel off the ground, you lose drive traction. It's one of the
    in- built limitations of a differential. So don't sweat that too much...
    Wheelhop is usually insufficient damping for that sort of shenanigans, and
    the rear trailing arms seem to do it a lot, at least in every street iteration I've driven.
    How stiff are those springs in back?
    t
    • tuddy
      • Feb 2014
      • 99
      t
      Im not sure the spring rates on them, they're pretty darn stiff tho.
      Someone has suggested to me rear subframe bushings which i hadnt though about. Im going to inspect them this evening.
      • tuddy
        • Feb 2014
        • 99
        rear subframe bushings in tact from what i can tell.
