Transmission oil?
  • duffyboby
    • Oct 2013
    • 75
    Transmission oil?
    Ok so I was planning on changing the oil in my transmission and having done a bit of research i went with general concensus and bought 2 quarts of redline mtl. Now i just got around and change the oil today and drained it to realize i have atf in it. Now i looked around for any label that said it is a atf only tranny bud didnt find anything. Should i go ahead and fill it up with redline mtl or go buy some atf? Thanks
    88' 325iX 126k
    • 37833
    You're fine with the MTL.
    Grover Beach, California
    BimmerHeads.com
    • Poorboyz
      • May 2012
      • 2117
      Redline is perfectly fine.
      Sent from my 831C using Tapatalk
      Rebuilding since 07/06/2016
      Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
      Poorboyz Feedback Thread
      • george graves
        • 20003
        Well, redline is more-or-less top of the line(someone correct me if I'm totally wrong). I use it on my e30m3 tranny (g265) - just cause I know how much a replacement costs. If I had a stock e30 tranny - even turbo'ed car, I'd consider how little a used tranny costs compared to the cost of redline each year. My 2 cents.
        Originally posted by Matt-B
        • Poorboyz
          • May 2012
          • 2117
          Top of the line or not...it's a few extra dollars and I'm sure even you doesn't want to go out changing a trans...no matter if it cost $50 or $1000 for a new/used trans.
          I can tell you it was night and day difference for me when I put in Redline.
          • estoguy
            • May 2013
            • 1087
            I went with the Redline MT-90 - my tranny had the green sticker. The oil has been in almost 2 years, and has been just fine.
            Estoguy
            • Smelser
              • Feb 2011
              • 633
              Used diesel engine oil with a mix of varsol to thin it. works like a charm!
              sigpic1984 318i Total conversion to a DIRT race car.
              Check out our build on facebook @ www.facebook.com/brewstermotorsports
              • MatRacer
                • 562
                Do you drive it in the winter? Non atf may be rough on -30C morning...
                E30 now S52
                2008 Suburban LTZ (Family and TT hauler)
                325xiT (Sold)
                • estoguy
                  • May 2013
                  • 1087
                  You won't have problems with Redline in the cold. ;)
                  Estoguy
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    We keep race cars prepped at the shop. Even changing the fluid every other event (4 or so times a year) it doesn't cost as much as a used trans. MTL is $15/qt, so that's $120/yr for the race cars which are getting far more changes than a street car.
                    john@m20guru.com
                    Links:
