Any anti-rattle mods for 260 Getrag ?
  • fporro
    • 1860
    What else can I do to a rebuilt 260 Getrag to keep single mass lightened fly wheel from rattling at idle ?,
    Besides upgrading to a Brass or Steel Performance Clutch Pivot Pin,
    is there an upgrade for the Trow Bearing ?
    or anything else ?
    Clutch will be a SPEC stage 2+.
    Mahalo,
    Frank
  • SpecM
    • Oct 2005
    • 4531
    performance clutch pivot pin
    I did not know such a thing existed
    1989 cirrisblau-metallic 325i
    • TobyB
      • 5293
      240-800w gear oil may help the rattle,
      but it's going to kill your shifting...
      hee hee...
      t
      • LJ851
        • 7919
        Add 2 cups of sawdust to the gear lube.
        Lorin
        The M30 is God's engine.
        • Lugnuts
          • Oct 2014
          • 136
          2 parts Redline MTL, 1 part Redline MT-90.
          • rcsoundn1
            • Nov 2012
            • 3361
            i never knew that existed, in for more info i guess
            • 1craze30
              • 1224
              I use a quart redline 75w140NS, and top off with redline atf. Had rattle, but it's gone, and after a spirited drive it's still quiet
              • Northern
                I like cupcakes & sh!tboxes
                • 5283
                FYI metal clutch pivot pins come factory on the E31 850CSi. Probably cheaper to buy that through blunt than an aftermarket one.
                Originally posted by priapism
                Originally posted by shameson
                • jwal
                  • Apr 2014
                  • 385
                  PN: 21511223281
                  Still about 20-25 bucks everywhere I found it. Cool info though :)
