Clutch will NOT bleed!!!
  • vdubspeed
    • Dec 2014
    • 28
    I have done every method I can think of! I bought this 325i with a known bad master cylinder.
    Replaced just the master cylinder as it was included and that got the car running but my clutch released just off the floor. So I decided to pony up and buy a slave cylinder too.
    The new slave cylinder never made a difference.
    I have reverse bleed, pressure bleed, gravity bleed, removed the slave and forced the piston back in all the way and nothing gives a firm pedal.
    Please let me know what worked for you cause I'll give it a shot. If I can't get it...it's going to our local indy shop who I like but I hate to admit defeat.
    Regards,
    Jason
    Built > Bought
    58 Beetle | 79 Rabbit 20vT | 84 GTI TDI |84 GTI 16vT |12 Golf TDI ----89 325i | 99 QCSB Ram Cummins | 02 Burb 4x4 2500
  • uturn
    • Dec 2010
    • 1007
    The bleed screw being on the bottom makes it tricky. There's a jig that allows you to bleed it off the tranny. I'm thinking a clamp and a piece of wood would work too. If you get pressure with it in the C-clamp then your clutch fork is likely broken, otherwise you blew the seals in the master or slave.
