Drive shaft difference between "e" and "i" manual
  • MrNatural
    • Apr 2008
    • 237
    I have an '87 e manual and I'm planning to replace the ds and the tranny also go with a single mass flywheel instead of the dual...so are there any differences I should be concerned with for the ds? I plan on getting the rebuilt ds from
    http://www.wholesaleimportparts.com and the tranny from http://www.catuned.com/catuned-getra...ansmission-e30 and if I'm not mistaken the clutch is as simple as getting the clutch kit with single fw and shorter bolts? The guy at the ds store said there were differences in length (not much maybe an inch but enough to be a problem) If the tranny is from an "i" model it's fine because I'm converted to all "i" components...just need the right ds...LOL somebody here has to know this!
  • gotane30
    • Apr 2013
    • 332
    realoem is your friend on this one pal.
    • MrNatural
      • Apr 2008
      • 237
      Went there and the part numbers are different but the lengths are the same...
      • gotane30
        • Apr 2013
        • 332
        did you check the guibo/flange outputs on the two? That would probably be the reason for different part numbers.
        • Wishno87
          • 6025
          87 eta should be large guibo.
          • MrNatural
            • Apr 2008
            • 237
            The tranny will more likely be an "i" type so they should be the smaller flange from what I've read...so I'm thinking an '87i ds should work...right?
              • 37832
              As long as they are both from manual cars and both use the same size guibo they will interchange.
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
              • MrNatural
                • Apr 2008
                • 237
                I'm trying to find out if the tranny comes with the flange...
                • TobyB
                  • 5263
                  It will- I bet if you contact your proposed supplier they'll give you the answers you need.
                  Far better than we will be able to!
                  t
                  • jayuuey
                    • 414
                    You can just swap the output flange to match your driveshaft, right?
                    • reelizmpro
                      • 9542
                      You need to ask CA tuned what size the flange is on the trans you buy. Then get the matching DS.
                      88 M3 - LACHSSILBER
                      89 M3 - ALPINEWEISS II
                      • MrNatural
                        • Apr 2008
                        • 237
                        Good answer...that's exactly what I did. They can put whichever you want so I opted for the small.
                        • wakeboardr42393
                          • Apr 2013
                          • 186
                          isn't the trans for the single mass flywheel physically shorter then the trans for the dual mass flywheel? I know the bellhousing is longer on the dual mass transmission.
                          '87 325is [because racecar]
                          '81 Kawasaki KZ550 LTD {summer dd}
                          '97 Subaru Legacy Outback Limited (winter dd)
