Mig Weld diff for BMW E30 318is
  • MagicMiura
    • Jun 2015
    • 21
    Hi. I´m building a BMW E30 for rallyes and trackdays.
    I have 4 stock diff and I just want to use one of them for have some fun on the race track.
    Mig Weld could be a cheap solution.
    For 136hp can be strong or it´s a suicide?
  • Doughnut
    • Oct 2007
    • 869
    136hp is poo, weld those spider gears up!
    ///Monstrosity. (OO≡≡[][]≡≡OO)
    Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
    • MagicMiura
      • Jun 2015
      • 21
      Oks. Thanks for your time.
      • cabriodster87
        • Jan 2011
        • 1042
        Is the backside of that gear housing open like shown or not? There is a trick way to lock them solid without welding.
        I done it to ford 9" carriers when rules at my track read "NO welding on gears, spools, or mini spools" lol, the next year they had to revise their rules.
        Reich und Roll!
        • TobyB
          • 5298
          The small case diff can be welded up at the spiders, no problem. I found they lasted
          just fine as long as you didn't let the carrier heat up much. If you try to weld the spiders
          to the carrier, sometimes the carrier doesn't survive the process, or distorts.
          I've welded half a dozen with a 120v mig, and so far, none have failed. Well,
          the welding hasn't- I got slag in one, and didn't catch it,
          and that chewed the gears up pretty quickly.
          Preheat to 400f or so beforehand, and alternate your welding, and it works just fine.
          t
          • Doughnut
            • Oct 2007
            • 869
            t
            Good idea.
            Be sure to remove all of the oil before welding to get the best penetration.
            I feel sorry for your tyres already
