changing trans fluid on g260/5
  • Mr. Burns
    • Aug 2011
    • 3516
    I am ever so close to driving my E30 after 1.5 years...I don't want to take any chances with the M30 G260 5spd transmission I pulled from a PnP.
    do I need one of those transfer pumps in order to replace the fluid?
    this is something I should of done while everything was out ffs...but oh well.
    if not, I'm having a little difficulty finding a quick DYI
    Originally posted by flyboyx
    i have watched my dog lick himself off a few times
  • noid
    • 1537
    Change your E30 transmission fluid the easy, cheap way: the 17mm hex trick, fluid choice and fill/drain plug tips.
    Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
    Your resource to tools and tips: www.rtstools.com
    • Mr. Burns
      • Aug 2011
      • 3516
      Thanks noid
      • estoguy
        • May 2013
        • 1087
        Another decent way to get it in is to get transfer pump. Get one that works like a giant syringe. Should be pretty easy peasy.
        One note - open the fill nut BEFORE you drain, just to be sure you'll be able to refill it. ;)
        Estoguy
        • TobyB
          • 5293
          I hang a funnel off of the passenger's side mirror and run the length of vinyl tubing UNDER the car.
          When fluid starts pouring back out of the fill hole, I crawl under, get stinky, and put the plug back in.
          That way I don't run the risk of getting MT inside the car. Stuff stinks...
          t
