Short Shifter
  • bcbimmer
    • Mar 2006
    • 59
    Short Shifter
    hey guys wondering if i were to buy a z4 shifter and put it into a 1990 325i would i have to have it bent ? also is Bma the way to go ?
    thanks
  • optimusp517
    • Oct 2005
    • 797
    re"search" ;) and no you don't need to bend it I don't recall. BMA works perfectly fine I've ordered from them and Patrick is a great guy to deal with!
    • kencopperwheat
      King of Kegstands
      • 14396
      you'll have to either bend it or take out your harmonic balancer on the driveshaft.
      Originally posted by Gruelius
      • James Crivellone
        Head Janitor
        • 6305
        you technically need to bend it anyway if you want it perfectly centered in the shift console.
        I had to do that with my M Roaster lever.
        • ToplessE30
          • 4791
          How would one go about bending these levers?
          Estoril E36 M3/4/5 | Toledo E53 X5 3.0 | LeMans E90 335D M-Sport
          • browntown
            • Jun 2004
            • 3524
            read and learn: http://home.onlineok.com/~compman/Artwork/bendinst.pdf
            • NC325iC
              • Mar 2004
              • 6565
              you dont have to bend the lever, you have to bend the selector rod or remove your harmonic balancer
              • bcbimmer
                • Mar 2006
                • 59
                what does the hermonic balancer actually do ? if i were to remove it is there any down side to not having it ? if i just removed the hermonic balancer would ther be a need to bend it ?
                • rede30
                  • 4697
                  To bend the harmonic balancer you can just get creative with a table vise and three sockets. You can take the harmonic balancer off and not bend the rod, this might give you a slight vibration at higher speeds and you might feel a small bit of power after taking it off. I got the z4 ssk and i bent the rod and have been happy with that but my DD has the z3 ssk and i also like that kit and you dont have to mess with the rod. Good luck with what you choose, ssk kit is a very nice thing to have. I also say you should make a clutch stop, this complements the ssk and is very cheap to make at home depot.
                  • ToplessE30
                    • 4791
                    Originally posted by browntown
                    Good read. Thanks.
                    • arsevader
                      • May 2005
                      • 1025
                      Don't bend the vibration damper. ;)
                      • kencopperwheat
                        King of Kegstands
                        • 14396
                        If you don't bend it, the lever will sit SLIGHTLY forward and to the right in the console (I can't even notice), since it's a straight lever (the stock ones are bent).
                        • moatilliatta
                          • 6151
                          ha ha harmonic balancer
                          @Zakspeed_US
