STILL have a drone/vibration driving me insane
  • Sea Aych
    • Apr 2013
    • 767
    car: M50 swap, stock Getrag 260, driveshaft, 4.10 diff.
    I just had my driveshaft rebuilt (new u-joints, csb, balance, etc.), thinking it would solve my problem, but it hasn't...
    I'm getting a LOUD droning noise above 30mph, getting loudest at around 45mph. It sort of sounds like it's coming from the back, but it's hard to tell since it resonates through the whole cabin. There is a slight vibration that goes along with it, but it's smallish compared to the noise.
    It's entirely speed dependent, as it continues if i pop the clutch in, or go the same speed but in a different gear (different revs)
    My headers aren't touching the subframe or the sway bar, i'm on stock trans mounts, guibo is looking fresh, and the driveshaft (as mentioned) is just rebuilt professionally.
    I'm at the end of my rope and have been battling this extreme drone for almost six months now. Any more ideas?
    Any other ideas?
    1988 Atlantisblau Euro/Japanese 325i Cabrio
    1989 Schwartz 325i - now M50 powered! - now very dead
    1998 Toyota 4Runner Limited - gone
    My 17,000km Big NA National Parks trip!
  • Varinn
    • 780
    Wheel bearings?
    1990 332i, 4 door
    2008 KTM 990 Superduke
    2018 Golf R, 6spd manual (Pending delivery)
    2017 Mazda CX-5 GT
    2007 Z4M Coupe - Sold to very nice people
    • Tim-sutherland
      • Dec 2014
      • 115
      Originally posted by Varinn
      Wheel bearings?
      Sounds about right to me. I could think straight again after mine were replaced.
      • packratbimmer
        • Dec 2009
        • 1335
        Can you alter the drone by accelerating/decelerating? If your rear subframe bushings are completely shot, the new u-joint in the back will be on a bind. Jack the car up from the center (diff.) enough to see if the rear subframe bushings are sloppy.
        • Sea Aych
          • Apr 2013
          • 767
          Doesn't seem like it as i couldn't make it change tone with turns. then again it's a little hard to turn sharply enough in town at 70kph without attracting a ton of attention
          Do they cause a droning noise + slight seat vibration to match when they're going?
          Closest way i could describe the sound would be a BRRRRR with a fast faint bumbumbum going on underneath.
          Bushings look decent, definitely no play
          • Varinn
            • 780
            If nothing else they are an easy thing to check, you can lift the car one corner at a time and do a top/bottom and side to side check by by grabbing the wheek and giving it a bit of force in each direction (push/pull). Fronts you can also check condition by giving them a spin by hand, they should be very smooth with a slight resistance and spin down after a few rotations. If they spin easily 10+ times they are dry and have more clearance inside from wear.
            1990 332i, 4 door
            2017 Mazda CX-5 GT
            • Sea Aych
              • Apr 2013
              • 767
              No play in the rears, seems to be fairly smooth too.
              I can hear a faint whine from the rear right when driving, but it's hard to tell with the level of drone
              • Sea Aych
                • Apr 2013
                • 767
                update - switched out my trans mounts, re-preloaded the csb, which helped a little, but oddly enough it now sounds like the noise is coming from right between my ass and the firewall....
                lost. CVs are fairly clunky when setting off, but there's no popping noises. could that still cause a rumbly vibration?
                • Fixedwheelnut
                  • Dec 2015
                  • 4
                  If you have a thumping as well how about tyres out of shape, jack it up on stands and drive it up to speed and look at the tyres.
                  • Sea Aych
                    • Apr 2013
                    • 767
                    Well I think that did it!
                    It was hard to tell until I had it running on stands with someone else at the wheel so I could look under.
                    The right axle isn't rotating on its own centre axis..... Hence the vibration. Speed up and it's a blur compared to the drivers side which is stable and spinning nicely.
                    CV joint is done. New axle time!
