1-series six speed gearbox on m50 m52 m54??
  • Arn02
    • Sep 2014
    • 8
    I'm looking into a 6-speed swap. I know the >2004 330i ZF boxes fit, but it's much easier finding 1-series six speeds over here. I reckon the bolt pattern will match, but I'm not sure about the angle (30 deg or not). I haven't found a build so far that has used this box.
    Has anyone any info on the possibilities?
    • 34835
    it will bolt up, and the angle is the same. you will need to use the flywheel that matches the transmission - the input shaft is shorter and the pilot bearing installs into the flywheel instead of the crankshaft.
    • Arn02
      • Sep 2014
      • 8
      Good solid info, thanks. Do you know if it has been done and blogged before? I spend an hour googling but didn't find any concrete links.
