Grinding noise when turning
  • M20
    • Mar 2016
    • 25
    Hi there,
    I'm running into an issue that sounds like it's coming from the rear. Grinding comes from lower speeds it seems, ~10-15mph.
    I'm not positive if this is or isn't suspension noise, but I think it's rear differential noise. I did just replace the rear diff fluid with redline 75w90 and the intensity of the grinding has decreased somewhat - but it's still there.
    Here's a short video of the noise: https://vid.me/PxPz
    Excuse the squeaky noise, that's coming from my steering column that I'll have to sort.
    Here's my options list based on VIN;
    I'll have to wirebrush off the tag on the differential once I have it back on the jack again.
    Has anyone had experience with this?
    Bronzit beige 1986 325es
    Burgundrot 1986 325e
    • 34834
    usually a diff will wine in a straight line too, and the noise will increase with speed. At low speeds and around corners, I think it's a wheel bearing.
    • M20
      • Mar 2016
      • 25
      Thanks Nando. I recently replaced the front bearings, I would've imagined that they would've had a hum to them in a straight line if they were the rears, but I guess I'll be reading up on that.
      I'd much rather replace a couple of bearings over a diff any day.
