UUC Evo shifter play
  • Rob Daman
    • Sep 2014
    • 104
    Hey guys,
    I just picked up a e30 w this short shifter and I noticed there's a lot of up and down play on this shifter.
    The circlip appears to be in the groove but when pulling on it, to me it's a substantial amount of play. I was told 2-3mm is fine but this look way more.
    what are your thoughts?
    thanks
  • TobyB
    • 5280
    Is this the kind with a couple of allen- head bolts in slots holding it in?
    I've seen those wear. Or lose one.
    Otherwise, if it was mine, I'd shim it and call it done.
    t
    • rturbo 930
      • Dec 2005
      • 2625
      As I recall, it has a spring in it right there. I had a similar problem. I don't know if it was something I did or not, but I never liked how it shifted.
      • Rob Daman
        • Sep 2014
        • 104
        yea it is. all the bolts are there but since i couldn't find my metric allen wrench i just tried with what i had. i should have just used a small needle nose.
        i did as you just said. i tried a rubber washer but that failed. found some metal E clips that I grinded own as a shims. now it's better but still floppy.
        yea there's a spring. the cup thing is still loose. the PO apparently didn't use enough loctite.
