m20 with Getrag 420g?
  • HerbE30
    • Nov 2015
    • 538
    There difference is only off by 10° as opposed to the 15° that would have to be twisted if I m50 swapped. Long story short I plan on doing a swap in the future to m6x probably. But I know a junkyard with a s38 as well. But even if I end up with an s/m5x that 420g will still fit all across correct. I realize it's just an overdrive gear with the 420 but I live in a town where people only respect/work on chevy/ford. So I see this tranny a lot for low low prices
    Anyone done this? I think only 4 of the torx bolts line up with an m20 as well. You guys think that's sufficent? (I kinda do)
    20% Accurate
    Morty: Well Summer maybe people that create things aren’t concerned with your delicate sensibilities you know? Maybe the species that communicate with each other through a filter of your comfort are less evolved that the ones that just communicate? Maybe your problems are your own to deal with and maybe the public giving a shit about your feelings is a one way ticket to extinction.
  • TobyB
    • 5298
    ...just get the S38- everything else is easy...
    hee
    t
    • JGood
      • Jan 2004
      • 7959
      The 420g won't bolt up to an m20/m50 block. The bolt pattern is completely difference, among other things.
      e30 restoration and V8 swap
      24 Hours of Lemons e30 build
      • HerbE30
        • Nov 2015
        • 538
        The getrag 420 was used in the e36 m3 euro... Why would it then not fix s5x/m5x? Answer me that JGood?
        Just read some info on the m5x to 420g here http://www.bimmerforums.com/forum/sh...-%28Sticky-%29. So why not m20? It I went for a 10 degree switch on the sifter linkage and rotated it back when I swapped another motor in?
        20% Accurate
