Redline MTL Question
  • E30newb6
    • Feb 2016
    • 21
    So I recently changed my manual trans fluid and differential fluid with redline MTL in the trans and redline 75w90 in the diff. I read a thread (which I cant find now) that said they used two FULL bottles for the trans and under 2 for the diff. My car is an '87 325IS, but my trans barely took 1.5 bottles before it started spewing out. Now cold shifts are much better (what I was trying to fix), but its still really notchy, if not notchier than before, at operating temperature. Are you supposed to overfill it or was I right to stop once it started coming back out?
    Thanks
  • agent
    Vice Grand Pubaa
    • 7960
    Moved to the appropriate section. The FAQ/DIY section is for staff-approved instructional posts only.
    Originally posted by kronus
    • e30 gangsta
      • 3877
      Once it starts pouring out your good.
      • estoguy
        • May 2013
        • 1087
        By the book, a 325 takes 1.25L in the transmission and 1.7L in the diff. If you're pouring out more than 2 L, you're doing something wrong.
        If the car is level, there should be a small trickle coming out without the fill plugs in. Or stick your finger in the hole. If you can feel oil at or just below the threads, you're good.
        Estoguy
        • TobyB
          • 5280
          I usually manage to get 1.5 qts into the trans.
          That works.
          t
