new 325is transmssion question
  • e30fix
    • Sep 2014
    • 311
    hey guys, i ended up buying a 89 325is automatic from some guy on craigslist. the car itself isn't in the best of shape,in fact its actually a pos cosmetically. well iv decided to save the dam car, and will use an 1986 325 es production date 9/86 with a 5 speed in it as the donor car.
    iv read a few things about transmission being compatible with the 89is but could i use my complete drivetrain? from rear subframe, differential, driveshaft, center bearing and transmission. iv replaced many of these parts and would like to keep them. will this be a straight forward swap or do i have to mix and match the parts in order for it to work.
  • Steve Corbett
    • Jul 2012
    • 449
    Yes, most all the parts should fit. The flywheel for the I is different then the E motor though. The I is much lighter.
    Steve Corbett
    1983 528E Scrapped
    1983 528E Sold
    1984 745I
    1984 325E - Sold
    1989 325I Bronzit-Sold
    1989 325I Zinno
    1988 635CSI
    • jeffnhiscars
      • Jun 2011
      • 6011
      You will need to use the drive shaft from the manual trans
      Alice the Time Capsule
      • e30fix
        • Sep 2014
        • 311
        awesome thanks for the replys guys. yeah i figured i would just pull the complete subframe from the e car and through it in my IS since all the bushings are new. ill keep the differential and driveshaft from the e car as well. i should start this project in the next few weeks so ill let you know how it goes. thanks.
        • jeffnhiscars
          • Jun 2011
          • 6011
          Stick with the i diff.
          • TobyB
            • 5298
            You will need to use a late style csb no matter which driveshaft you use.
            It will fit either ds.
            t
            • e30fix
              • Sep 2014
              • 311
              ok i ordered the csb today and a few other things im going to need to get this going.
              i was also thinking about keeping the i differential but its a 4.10 lsd. the lsd in my es is a 2.93 lsd and would be better for fuel and street driving since i rarely commute long distance.
              • e30fix
                • Sep 2014
                • 311
                still havent order the clutch. any recommendations of which one to get?
