Z3 Diff Question
  • A4cams
    • Mar 2015
    • 17
    Z3 Diff Question
    Is there a way to determine the gear ratio on a Z3 Diff from the last 7 numbers of the Vin? I was told it is a "3.2 LSD." Its from a 98 2.8 Manual Z3. I assume that it is a 3.23 LSD given the year of the car and motor/trans. Appreciate the help.
  • itsonlygeorge
    • Feb 2014
    • 852
    Should be 3.23 or 3.15. Non-M Z3's used a torsion diff. Only the MZ3 had an 3.23 clutch type LSD.
    1987 325e Lachssilber w/ MarkD chip and late bumpers, Zender EVO spoiler, s3.25 LSD
    Originally posted by nando
    I don't think there's really strong evidence that ZDDP harms cats.
    • The Dark Side of Will
      • Jun 2010
      • 2796
      Do you not have it yet? Is the ratio tag not on it?
      • stonea
        • 2892
        There isn't a tag on either of my Z3 diffs.
        My Garage
        Feedback
        Instagram: Stone.Hopkins
          • Jun 2010
          • 2796
          Funky. My dad bought two 3.07 torsen Z3 diffs and I could have sworn they had tags.
          • stonea
            • 2892
            Hmm, I wonder if it has anything to do with the model. Both of mine are are from a 2.5 Z3. One from a 2001 M54b25, and the other from a 1999 M52tub25 (I believe thats a 3.15 ratio). Both are also extremely low miles (less than 25,000 miles when they came into my possession) so I don't believe the tags were removed.
            Edit: Well I guess the M52tuB25 Z3 was technically labeled as a 2.3 liter
            My Garage
            Feedback
            • rcarradine
              • Sep 2012
              • 31
              I was just looking at a 3.15 diff from a '99 2.5 Z3 and couldn't tell if it was open or LSD other than rotating the shafts. Is there a way to check this by the diff sticker? Or vin for that matter?
              • Jaxx_
                • Dec 2009
                • 1880
                if you have the differential and you are curious about the ratio, just spin the pinion and count the rotations out. You can do it 10x for more accuracy, just requires a little more math. edit: I'm an idiot.
                You can determine the car's vin attributes and then see if you can find a reference table for the combination/diff ratio. For example, my e46 touring had manual and sport package and is a 323i. You can then determine that it had a 3.46 in the rear based on other information on the internet.
                Search for a vin decoder. It likely won't tell you the ratio directly, but it will probably help you find it.
                • reelizmpro
                  • 9543
                  It should have a Torsen LSD.
                  Torsen's have a blue washer around the speed sensor.
                  88 M3 - LACHSSILBER
                  89 M3 - ALPINEWEISS II
