Shift into Fifth Gear issues
  • mjposner
    • Aug 2015
    • 169
    I have a low mileage E30, and all the gears feel normal except the shift into fifth feels odd compared to other 5 speeds (including e36) that I have driven. Its not like the 2nd to 3rd shift, more of an up, side up movement instead of a diagonal movement. Is this normal? Would a z3 short shift kit fix the issue? I am using a zhp shift knob.
  • vpilarrt
    • Jun 2006
    • 2096
    May want to check the shift rod and shift arm bushings.
    • TobyB
      • 5298
      There's your problem.
      The ZHP shift knob is only for 6- speeds.
      t
      • mjposner
        • Aug 2015
        • 169
        t
        Where did you get that idea??
        https://www.turnermotorsport.com/p-3...ttern/?pdk=AQE
        https://www.ecstuning.com/b-genuine-...d/25117896031/
        • TobyB
          • 5298
          I made it up on the internet. Pretty good, huh?
          t
